<?php function login_check() { if (isset($_SESSION['IWP_loggedIn']) && $_SESSION['IWP_loggedIn'] === true && isset($_SESSION["IWPUser"])) { return true; } else { return false; } } function do_login($username, $password, $redirect) { $un = 'DOMAIN\\' . $username; // Needs the domain ie. mydomain\username $pw = $password; if (empty($un)) { header("Location: http://example.com/sandboxPHP/login.php?error=Username cannot be blank"); exit(); } if (empty($pw)) { header("Location: http://example.com/sandboxPHP/login.php?error=Password cannot be blank"); exit(); } $server = "example.com"; //IP or name of server here if (!($ldap = ldap_connect($server))) { header("Location: http://example.com/sandboxPHP/login.php?error=Could Not Connect To Server"); // can change these error messages exit(); } if (!ldap_set_option($ldap, LDAP_OPT_PROTOCOL_VERSION, 3)) { header("Location: http://example.com/sandboxPHP/login.php?error=Protocol Error with LDAP"); exit(); } if (!($res = @ldap_bind($ldap, $un, $pw))) { header("Location: http://example.com/sandboxPHP/login.php?error=Bind Error with LDAP"); exit(); } else { $_SESSION["IWP_loggedIn"] = true; $_SESSION["IWPUser"] = $un; // Make sure to use appended username with Domain echo $_SESSION["IWPUser"]; //header("Location: " . $redirect); } } function do_logout($redirect) { session_destroy(); header("Location: " . $redirect); } ?>
<?php session_start(); echo $_SESSION["IWPUser"]; require('functions.php'); if(login_check() === false) { echo 'issue'; //header("Location: "); exit(); } else { // rest of your page below } ?>
<?php // Start session to track this users identity session_start(); // Make sure they are logged in, if not redirect to login // IWP_loggedIn is boolean, 'true' if (!$_SESSION['IWP_loggedIn']) { // Redirect to the secure content header("Location: http://example.com/login.php"); // Make sure that code below does not get executed when we redirect exit(); } else { //talk to ArcGIS Server/Web Adaptor to tell it the users credentials } ?>
<!DOCTYPE html> <html> <head> <title>Secure Access</title> </head> <body> <?php // Start session to track this users identity session_start(); // Make sure they aren't already in a session; if so, redirect to GIS Home // IWP_loggedIn is boolean, 'true'; if there is a session, credentials are already stored if ($_SESSION['IWP_loggedIn']) { // Redirect to the secure content (ArcGIS JavaScript app with secured ArcGIS Server services) // header("Location: http://example.com/gis.php"); // TEST MODE: print the authorized user name echo $_SERVER['LOGON_USER']; // Make sure that code below does not get executed when we redirect exit(); } else { // If no session is started and no authentication has been performed if (empty($_SERVER["LOGON_USER"])) { // If user is not in intranet, or browser is not enabled for SSO // IIS/browser prompt for credentials; this message is a stand-in for now echo "<h1>Please login with your credentials to access GIS data</h1>"; // Create session logged-in variable to track user $_SESSION['IWP_loggedIn'] = TRUE; // Store credentials (how do I pass on username/password or key to the next site?) $_SESSION["IWPUser"] = $_SERVER["LOGON_USER"]; //Redirect, credentials passed via PHP session // header("Location: http://example.com/gis.php"); // TEST MODE: print the authorized user name echo $_SERVER['LOGON_USER']; // Make sure that code below does not get executed when we redirect exit(); } // If user is on intranet and browser is enabled for SSO, automatic login occurs // "LOGON USER" field will be filled, auto-redirect to map if (!empty($_SERVER["LOGON_USER"])) { echo "Oh Joy!!!"; // Create session logged-in variable to track user $_SESSION['IWP_loggedIn'] = TRUE; // Store credentials (how do I pass on username/password or key to the next site?) $_SESSION["IWPUser"] = $_SERVER["LOGON_USER"]; // Redirect, credentials passed via PHP session // header("Location: http://example.com/gis.php"); // TEST MODE: print the authorized user name echo $_SERVER['LOGON_USER']; // Make sure that code below does not get executed when we redirect exit(); } } ?> </body> </html>
