onExtentChange levelChange is of type Extent not Boolean
1818
05-15-2013 03:54 PM
JaniceBaird
Has anyone run into this issue? I am trying to use the levelChange object when the extent of the map changes. The documentation says that it should be Boolean but I am getting an Extent Object.
I am using javascript api 3.3, dojo 1.8, arcgis server 10.1
thanks,
Janice.
ShreyasVakil
onExtentChange event has 4 parameters and first one always return an extent object. If you want a levelChange boolean use the following and you would get a boolean for levelChange:
dojo.connect(map, "onExtentChange", function(extent,delta,levelChange,lod){   console.log(levelChange);  });
Let me know if it helps!
Shreyas
ShreyasVakil
Shreyas
by Anonymous User
Not applicable
Original User: janiceb
Shreyas,
Thank-you! My brain is total mush today from too much work!
Your reply makes complete sense and I will try it out in the morning and give you a big "CHECK-MARK".
Janice.
