not getting any selection results, JSAPI 3.21 with WABuilder 2.5
1876
03-22-2018 03:37 PM
MattBorden
I'm using JSAPI 3.21 with WABuilder 2.5, getting the below error, not sure why?
my guess is maybe a bad where clause and not getting any selection results, or bad syntax and not using selection results correctly with JSAPI, any help would be great
thanks Matt
"esri/tasks/query",
"esri/graphic",
function(
Query,
Graphic,
//get layer
var currentLayer = this.map.getLayer(this.map.graphicsLayerIds[1]);
//create query
var query = new Query();
query.where = "parcel_id = '01364000010000'";
//query to get selection on feature layer
currentLayer.selectFeatures(query);
//get the extent
theExtent = currentLayer.getSelectedFeatures().geometry.getExtent();
//zoom to map extent
this.map.setExtent(theExtent);
debug results from chrome dev tools
RobertScheitlin__GISP
Matt,
  Here is a quick example of working with the deferred:
curentLayer.selectFeatures(query, function(result){
  //todo work with the selection result
  //now that the selection is complete
Matt,
  It looks like you need to wait for the selection method to complete before you try and access the selected feature. The select features method returns a deferred so you need to wait for the deferred to resolve.
MattBorden
thanks for the tip Robert, I'm trying timeouts and promises to see if this fixes it, I'll share the results when I have them
Matt,
