Not Able To Display Query Task Result on Graphic Layer
3980
12
09-27-2017 10:07 AM
BehrouzHosseini
Using ArcGIS API 3.21 and following code I am trying to populate the result of a Query Task on map by populating the result featureSet on GraphicLayer but I am not getting any thing in result. and No error on Console. Can you please let me know what I am doing wrong?
var map;
 require([
 "esri/map",
 "esri/layers/FeatureLayer",
 "esri/layers/GraphicsLayer",
 "esri/tasks/query",
 'esri/tasks/QueryTask',
 'dojo/_base/array',
 "esri/graphic",
 "esri/symbols/SimpleMarkerSymbol",
 "esri/Color",
 "dojo/dom",
 "dojo/domReady!"
 ], function(
 Map, FeatureLayer, GraphicsLayer, Query, QueryTask, array, Graphic, SimpleMarkerSymbol, Color, dom
map = new Map("mapDiv", {
 basemap: "streets",
 center: [-88.155000, 41.784042],
 zoom: 14,
 slider: false
 var graphicsLayer = new GraphicsLayer();
 var markerSymbol = new SimpleMarkerSymbol(
 SimpleMarkerSymbol.STYLE_SQUARE, 10, null, new Color([50,50,255])
  var queryTask = new QueryTask("https://server.domain.com/arcgis/rest/services/ElectricData/FeatureServer/3");
  var query = new Query();
   query.where = "1=1";
   query.returnGeometry = true;
   query.outFields = [ "CreationUser"];
   queryTask.execute(query).then(onQuerySuccess, onError);
  function onQuerySuccess(featureSet) {
    array.forEach(featureSet.features, function(feature) {
    feature.setSymbol(markerSymbol);
    graphicsLayer.add(feature);
   map.addLayer(graphicsLayer);
  function onError(error) {
    console.error('An error ocurred in the query: ', error);
RobertScheitlin__GISP
Interesting. So you need to manually define the query out spatial reference then
query.outSpatialReference = {wkid:102100};
KenBuja
MVP Esteemed Contributor
If you want to use map.spatialReference, you'll have to wait until the map's spatial reference has been set in the load event (which fires when the first or base layer has been successfully added to the map)
BehrouzHosseini
Thanks a lots, it is working now!
