Needed recommendations for upgrade of website to ArcGIS JavaScript 4.*
2278
11-22-2023 05:31 AM
ekleiman22
I have a web site that uses  ArcGIS JavaScript 3.36. There are many modules based on this library and on dojo and dijit. For example, in main page index.html there is such part
require(["dojo/parser",
         "dojo/window",
         "dojo/on",
         "mapaSimple/MapSettings",
         "mapaSimple/BaseMapsMenuFacade",
         "mapaSimple/SearchMenuFacade",
and in module SearchMenuFacade.js I use
define([
"dojo/_base/declare",
"dijit/form/Button",
"mapaSimple/SearchMenuBuilder",
"mapaSimple/SearchMenuDialogRender",
"mapaSimple/SearchMenuActivity",
"dojo/i18n!mapa/nls/Resources"
function(
declare,
Button,
SearchMenuBuilder,
SearchMenuDialogRender,
SearchMenuActivity,
Resources
        return declare(null, {
            map: null,
            menuButton: null,
            setPointPosition: null,
        constructor: function(map) {
            this.map = map;
        createMenuButton: function() {
            var searchMenuBuilder = new SearchMenuBuilder(this.map);
            var searchMenuDialogRender = new SearchMenuDialogRender();
            this.menuButton = new Button({
                  class: "menuButton menuSearchButton",
                  iconClass: "menuSearchIcon",
                  label: Resources.menu.search.button
                 , onClick: function () {
                     searchMenuDialogRender.dialog.opened = true;
                     dojo.style(searchMenuDialogRender.dialog.domNode, 'visibility', 'hidden');
                     searchMenuDialogRender.dialog.show().then(function () {
                         dojo.style(searchMenuDialogRender.dialog.domNode, 'top', '100px');
                         if (getCurrentLanguage() != "en")
                             dojo.style(searchMenuDialogRender.dialog.domNode, 'right', '230px');
                         else
                             dojo.style(searchMenuDialogRender.dialog.domNode, 'left', '50px');
                         dojo.style(searchMenuDialogRender.dialog.domNode, 'visibility', 'visible');
             }, "menuSearchButton");
and so on. Here SearchMenuBuilder and others are different modules that also use dojo objects, "menuSearchButton" is html tag in index.html.  In index.html is link to the library:
 <script src="https://js.arcgis.com/4.28/"></script>
and also
var dojoConfig = {
            paths: { mapaSimple: location.pathname.replace(/\/[^/]+$/, "") + tail }
But when I browse the page I see  many errors showing that dojo objects not found. How this could be fixed?
JeffreyThompson2
MVP Frequent Contributor
The 4.X version of the API has been completely rewritten from the 3.X version. Most, if not all, of the Dojo components have been removed by now and complete removal of Dojo is a stated goal of the Dev team. You will probably be better off starting over from scratch than trying to convert your current code.
GIS Developer
City of Arlington, Texas
BlakeTerhune
Esri has some documentation about migrating an app from 3.x to 4.x that might be worth reading through.
Migrating from 3.x to 4.28 | Overview | ArcGIS Maps SDK for JavaScript 4.28 | ArcGIS Developers
There's also a functionality matrix that will help you locate comparable features.
ekleiman22
Thank you. I saw this page. But their description is not complete. For example, there is no "dijit/form/Button", "dijit/Dialog" and other things. I tried  simple example:
require([
  "esri/widgets/Button"
], function (Button ) {
and I get
4.28/:31 Error: scriptError: https://js.arcgis.com/4.28/esri/widgets/form/Button.js
because such URL does not exist. It seems that Button and some other  widgets from old version  are not included into new widgets library. At least I do not see them here esri widgets . Is there any possibility to use old dijit library in new web site based on ArcGIS JavaScript version 4.*?
ekleiman22
Thank you, JeffreyThompson2. Could you recommend what controls to use instead of dijit/Button, dijit/Dialog, dijit/form/CheckBox, dijit/form/TextBox, dijit/form/RadioButton,  dijit/registry ?
JeffreyThompson2
I never used the 3.X API, but you will probably find what you need in the Calcite components library.
GIS Developer
