Multiple Popups
901
09-29-2021 03:56 AM
MichaelK1
Hello
Is it possible to add mutliple popups on the map without an extension ?
ReneRubalcava
Esri Frequent Contributor
There is only one popup per View. If you want to try and simulate showing multiple popups, you can use the Feature widget, which displays Popup content and have multiple Feature widgets in your application.
Here is a sample showing multiple Feature widgets in a side panel.
https://developers.arcgis.com/javascript/latest/sample-code/widgets-feature-multiplelayers/
