MapView STUCK when +3000 graphics are VISIBLE (FeatureLayer)
1064
02-02-2022 12:51 AM
MichaelK1
Hi!
I'm using a FeatureLayer with some dynamic client sided data ( using applyEdits to update and add features ).
- map view
- custom simple markers / renderers
- 3000 +/- graphics drawn
And I'm not able to change the extent / navigate using mouse drag functionality. Browser memory is around 100-200mb.
Should I add something to improve the performance? There're only 3000 graphics drawn and with a simple marker without any fancy stuff...
Thanks!
If more info is needed feel free to ask
ReneRubalcava
Esri Frequent Contributor
Do you have a sample we can look at? I assume points? Does this happen on a particular browser or all browsers? Nothing stands out, we have samples using more data than that.
KristianEkenes
Also, how often are you making updates to the layer? Is it on every scale change, view pan, or using some other method?
