MapView goTo() not working in search.on("search-complete")
1051
03-14-2023 01:45 AM
PL1
I am using Arcgis/core version 4.24.
I have the following code inside view.when():
    let polylineSymbol = {
      type: "simple-line",  // autocasts as SimpleLineSymbol()
      color: [226, 119, 40],
      width: 4
    function createGraphic(line: any) {
      let polylineGraphic = new Graphic({
        geometry: line,
        symbol: polylineSymbol
      return polylineGraphic;
    function measureLine(vertices: any) {
      let line = createLine(vertices);
      let graphic = createGraphic(line);
      view.graphics.add(graphic);
    search.on("search-complete", function(event: any) {
      event.results[0].results.forEach((result: any) => {
        measureLine(result.feature.geometry.paths)
      // here I am getting just one graphic but to no avail.
      let xmax = view.graphics.getItemAt(0).geometry.extent.xmax;
      let ymax = view.graphics.getItemAt(0).geometry.extent.ymax;
      let xmin = view.graphics.getItemAt(0).geometry.extent.xmin;
      let ymin = view.graphics.getItemAt(0).geometry.extent.ymin;
      const extent = new Extent({
        xmax,
        ymax,
        xmin,
        ymin,
        spatialReference: { wkid: view.spatialReference.wkid }
      view.goTo({
        extent
      }).catch((error) => {
        console.log('result', error)
 But for some reason the code above does not work. Any suggestion on why the goTo() does not zoom into the extent?
PL1
Hello, and thank you for replying to my question!
I actually solved the problem by this way:
    color: COLOR_CYAN,
    width: HIGHLIGHT_WIDTH
  reactiveUtils.once(() => featurelayer?.loadStatus === "loaded")
    .then(async () => {
      addToSearchSources(featurelayer) // function that adds the layer to sources
      const result = await search.search(searchParam);
      const graphics = result.results[0].results.map((res: any) => {
        res.feature.symbol = polylineSymbol;
        return res.feature;
      graphicsLayer.addMany(graphics);
      view.map.add(graphicsLayer);
      view.goTo(graphics);
I also set the Search widget's autoSelect to false.
PL1
I changed the code so that I use
view.goTo(view.graphics);
But goTo() zooms to the first search result. This is not wanted. I would like to zoom on all of the graphics, instead of the first one.
UndralBatsukh
This actually (view.goTo(view.graphics) is the one of the preferred way to zooming into array of graphics. You don't have to do what you are doing in your first post.
I tested this with 4.24 and the MapView.goTo is working as expected. Here is a simple codepen shows It working: https://codepen.io/U_B_U/pen/wvEmEzw?editors=1000
PL1
    color: COLOR_CYAN,
    .then(async () => {
        return res.feature;
