MapServer doesn't support dynamic layers
3555
03-25-2019 07:33 AM
LarsFagerbakke
Hello!
I'm working with JS version 4.10 with a server on version 10.61 and I'm having some issues using MapImageLayer.
I've made a small application with one MapImageLayer with three sublayers. If I have more then one of the sublayers visible it starts to output error messages. Having one or none sublayer visible works fine, but I need to have more than one sublayer visible.
The error I'm getting is:
service .../MapServer doesn't support dynamic layers, which is required to be able to change the sublayer's order, rendering, labeling or source
Is this not supported by the server (v. 10.61) or did I do something wrong implementing MapImageLayer maybe? A feature I can turn on?
var layer = {
     url: ".../MapServer",
     subLayers: [
             name: "Not planned",
             visible: false,
             searchDisplayField: "Title",
             searchFields: ["Title"],
             popupTemplate: workOrderPopupTemplate
             visible: false,
             visible: false,
  var mapImageLayer = new MapImageLayer({
     url: layer.url,
     title: layer.name,
     sublayers: []
  map.add(mapImageLayer);
  for (var i in layer.subLayers) {
     mapImageLayer.sublayers.add({
         visible: layer.subLayers[i].visible,
         title: layer.subLayers[i].name,
         popupTemplate: layer.subLayers[i].popupTemplate
Tags (1)
RobertScheitlin__GISP
Lars,
   You should set sublayers like this (notice the descending order):
var layer = new MapImageLayer({
          url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer",
          sublayers: [
            visible: false,
            visible: false,
            visible: false,
Lars,
          sublayers: [
            visible: false,
            visible: false,
            visible: false,
LarsFagerbakke
Thanks Robert! I was not aware of this! 🙂
