Map and MapView autocast
1875
06-22-2021 03:01 PM
Shimoorook
On the documentation it's written that the Map class is autocasted for MapView class.
However, when Map module isn't imported in the beginning of the code with "esri/map", it doesn't seem to work. Am I misunderstanding how autocast works or is this a bug?
ReneRubalcava
Esri Frequent Contributor
Is there a particular way you're trying to create the map that doesn't work? I tried this basic example and the map works.
require(["esri/views/MapView"], (MapView) => {
  const view = new MapView({
    container: "viewDiv",
    map: {
      basemap: "topo-vector"
    zoom: 4,
    center: [15, 65]
ReneRubalcava
    map: {
    zoom: 4,
    center: [15, 65]
Shimoorook
Oh my bad..
My code was like below
require(["esri/view/MapView"], (MapView) => {
  cost view = new MapView({
    map: new Map({
    zoom: 4,
    center: [15, 65]
so when it's autocasted, there's no need to crate a new instance of the class and just provide the object with correct properties?
ReneRubalcava
That is correct. In some cases you need to provide a "type", like for renderers, symbols, geometry, etc. Those cases should be in the doc .
