Lower map sensitivity for touch devices
2105
09-17-2017 09:05 AM
MichaelLodes2
Hi all,
I have a problem with touching my points in the map. The problem occurs in all sample codes from esri I tested (for example Reference Arcade expressions in PopupTemplate | ArcGIS API for JavaScript 4.4 ). I want to open a popUp of a point object but when touching it with my finger/with a pen, the map shifts a bit. It shifts just a little bit despite concentrating on doing a "steady" touch movement. Doing 4-5 concentrated touches, the popUp opens sometimes. Working outdoor makes it additionally difficult.
This problem just occurs on the Samsung Tab Active!!! On all other tested smartphones/pc with mouse there is no problem. I already searched in android settings of the device to lower touch sensitivity but found nothing.
Is there any possibility to lower the touch sensitivity of the map itself?
SarahNoakes1
Hi Michael,
Did you ever get anywhere with this?  I'm having exactly the same issue.
Regards,
Sarah Noakes
Cornwall Council
MichaelLodes2
Which API version do you use? With 4.7 the sensivity is a bit better. But still not perfect I think. Many inspectors of my company still complain about that...
SarahNoakes1
We're still using v3.  I've just been looking at v4 and it is considerably better.  We've been holding off migrating until all the drawing tools are available, but maybe it's time to start shifting.
