Losing ui widgets after switch 2d/3D (maquette widget and more)
5945
17
02-07-2018 06:09 AM
TubaKumbara
Hello.
My application was shown 2D and 3D map on different divs until today.
Today i tried to show sceneview and mapview in same div . and tried code which on below link
Notice: My application starts with 3D.
ArcGIS API for JavaScript Sandbox
maquette widget generates error message when i try to change view from 3D to 2D and all of my ui widgets being disappear. But i never used maquette widget, maybe other widgets can use this. I have no idea.
0x800a139e - Javascript runtime error: NotFoundError
Problem -2
Adding Clock widget to sceneview but clock doesn't appear, Clockdiv is visible but has no clock inside. Just an empty div.
Clock widget was working without any error until change my code at today
thanks inadvance.
MetinGenç
Hi Robert. Same issue here. This is my sample code. Alerting before activating switch button widget. Please check.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Switch view from 2D to 3D - 4.6</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#infoDiv {
position: absolute;
top: 15px;
left: 60px;
</style>
<link rel="stylesheet" href="css/jquery-ui.css">
<script src="js/jquery-1.12.4.js"></script>
<script src="js/jquery-ui.js"></script>
<link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
<script src="https://js.arcgis.com/4.6/"></script>
<script>
require([
"esri/views/2d/draw/Draw",
"esri/Map",
"esri/views/MapView",
"esri/views/SceneView",
"esri/Graphic",
"esri/geometry/Polygon",
"esri/geometry/geometryEngine",
"dojo/domReady!"
], function(Draw, Map, MapView, SceneView, Graphic, Polygon,
geometryEngine) {
var switchButton = document.getElementById("switch-btn");
var appConfig = {
mapView: null,
sceneView: null,
activeView: null,
container: "viewDiv" // use same container for views
var map = new Map({
basemap: "streets",
ground: "world-elevation",
var initialViewParams = {
map: map,
zoom: 4,
center: [15, 65],
container: appConfig.container
// create 3D view and and set active
appConfig.sceneView = createView(initialViewParams, "3d");
appConfig.activeView = appConfig.sceneView;
// create 2D view, won't initialize until container is set
initialViewParams.container = null;
appConfig.mapView = createView(initialViewParams, "2d");
// switch the view between 2D and 3D each time the button is clicked
switchButton.addEventListener("click", function() {
switchView();
activateWidgets();
// Switches the view from 2D to 3D and vice versa
function switchView() {
var is3D = appConfig.activeView.type === "3d";
// remove the reference to the container for the previous view
appConfig.activeView.container = null;
if (is3D) {
// if the input view is a SceneView, set the viewpoint on the
// mapView instance. Set the container on the mapView and flag
// it as the active view
appConfig.mapView.viewpoint = appConfig.activeView.viewpoint.clone();
appConfig.mapView.container = appConfig.container;
appConfig.activeView = appConfig.mapView;
switchButton.value = "3D";
} else {
appConfig.sceneView.viewpoint = appConfig.activeView.viewpoint.clone();
appConfig.sceneView.container = appConfig.container;
switchButton.value = "2D";
activateWidgets();
// convenience function for creating a 2D or 3D view
function createView(params, type) {
var view;
var is2D = type === "2d";
if (is2D) {
view = new MapView(params);
return view;
} else {
view = new SceneView(params);
return view;
function activateWidgets(){
alert("activating switch button");
appConfig.activeView.ui.add("switch-btn", "top-left");
appConfig.activeView.ui.remove("attribution");
</script>
</head>
<body>
<input class="esri-component esri-widget-button esri-widget esri-interactive" type="button"
id="switch-btn" value="2D">
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
What browser are you using?
MetinGenç
Chrome But Internet Explorer has same error. Both of latest versions
Metin,
   Here is your code fix for Chrome.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #infoDiv {
      position: absolute;
      top: 15px;
      left: 60px;
  </style>
  <!-- <link rel="stylesheet" href="css/jquery-ui.css">
  <script src="js/jquery-ui.js"></script> -->
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
      "dojo/domReady!"
      geometryEngine) {
      var appConfig = {
        mapView: null,
        sceneView: null,
        activeView: null,
      var map = new Map({
        basemap: "streets",
        map: map,
        zoom: 4,
        center: [15, 65],
        switchView();
      activateWidgets();
        if (is3D) {
        } else {
        activateWidgets();
        var view;
        if (is2D) {
          return view;
        } else {
        return view;
      function activateWidgets() {
        //alert("activating switch button");
        appConfig.activeView.then(function(){
          appConfig.activeView.ui.add(switchButton, "top-left");
  </script>
</head>
<body>
  <input class="esri-component esri-widget-button esri-widget esri-interactive" type="button" id="switch-btn" value="2D">
</body>
</html>
MetinGenç
Thanks. It's worked on chrome and explorer.
MetinGenç
Thanks for code Robert but i'm still getting error message when switch between 2d and 3D.
Error : TypeError: Failed to execute 'appendChild' on 'Node': parameter 1 is not of type 'Node'
MetinGenç
Hi again Robert. Please open JSFIDDLE.NET (With Internet Explorer) and put this code and run. you will see Switch button is disappearing  after first toggling to 3d, then back to 2d.
<!DOCTYPE html>
<html>
<head>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#infoDiv {
position: absolute;
top: 15px;
left: 60px;
</style>
<script>
require([
"esri/Map",
"esri/Graphic",
"dojo/domReady!"
geometryEngine) {
var appConfig = {
mapView: null,
sceneView: null,
activeView: null,
var map = new Map({
basemap: "streets",
map: map,
zoom: 4,
center: [15, 65],
switchView();
activateWidgets();
if (is3D) {
} else {
activateWidgets();
var view;
if (is2D) {
return view;
} else {
return view;
</script>
</head>
<body>
</body>
</html>
TubaKumbara
Do you have any solution about this issue?
