Locate Button on Mobile
3679
12-04-2015 01:16 PM
RickeyFight
I have used Locate Button before in webapps and not had an issue.
I opened Locate Button | ArcGIS API for JavaScript  on my ipad and iphone it reloads every time I hit the locate button.
Has anyone else had this happen to them?
Maybe it is  bug in 3.15?
RickeyFight
I did find a work around. Which was what I suspected was the issue.
It hangs up because it is set to zoom in too far.
if you use the code:
    geoLocate = new LocateButton({
                map: map,
  setScale: false
            }, "LocateButton");
            geoLocate.startup();
It will work and not reload the page on an iPad.
