Lines look different on different zoom rate.
1020
01-22-2019 10:11 PM
BradJorgensen
Below, I have attached how the lines look on different zoom rate.
These lines are drawn based on this code. (JavaScript Code)
var baseX = Number, baseY = Number
for (var i = 0; i < 100; i ++) {
   var posArray = [
      [ baseX + i, baseY + i ],
      [ baseX + (i + 1), baseY + (i + 1) ]
   var graphic = new Polyline(map.spatialReference);
   graphic.addPath(posArray);
   var symbol = new SimpleFillSymbol(
      SimpleFillSymbol.STYLE_SOLID,
      new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([ 255, 255, 255 ]), 1),
      new Color([ 58, 58, 58, 0.8 ])
   var graphic = new Graphic(geometry, symbol);
   map.graphics.add(graphic);
And in normal, the lines drawn should be straight but as you see below, the lines drawn are not straight.
It looks straight on only max-zoom rate and on other zoom rates, it doesn't look straight.
Any solutions?
Minimum Zoom RateMaximum Zoom Rate
KevinTientcheu3
Hey Brad,
Are you working in a scene view? If so, there is a known limitation when working in scene views with lines which vertices are close together.
