JavaScript exception while using renderer on sublayers
1854
01-23-2023 06:06 AM
UgurcanErkal
Hi guys, I hope you are all doing well!
I have a strange exception in my implementation. The problem is when there is a popup in display, and if I want to zoom out, the Esri Library is throwing an exception. 4.24:2411 Uncaught TypeError: Failed to execute 'removeChild' on 'Node': parameter 1 is not of type 'Node'.
I'm not sure if it is related to my implementation. If required I can also share what I'm doing within JS.
Attaching this as well, maybe it helps.
UPDATE:
I found the problem source. It is the renderer that I have for my sublayers. When I remove them I'm no longer having the exception but I don't understand what is wrong with my renderer:
let rluLayer = new MapImageLayer({
                url: URL,
                imageFormat: "png24",
                imageTransparency: "true",
                listMode: "show",
                title: "RLU Program",
                sublayers: [
                        title: "Unavailable RLU",
                        definitionExpression: "Status = 'Available'",
                        visible: true,
                        // renderer: {
                        //     type: "simple",
                        //     symbol: {
                        //         type: "simple-fill",
                        //         style: "solid",
                        //         outline: {
                        //             style: "solid",
                        //             color: [255, 0, 0],
                        //             width: 1
                        //         color: [255, 0, 0, 0.2]
                        title: "Available RLU",
                        definitionExpression: "HuntingID IN (810004, 810005)",
                        // renderer: {
                        //     type: "simple",
                        //     symbol: {
                        //         style: "solid",
                        //         outline: {
                        //             style: "solid",
                        //             color: [76, 230, 0],
                        //             width: 1
                        //         color: [76, 230, 0, 0.2]
                        visible: true
let permitLayer = new MapImageLayer({
                url: URL,
                listMode: "show",
                title: "Permit Program",
                sublayers: [
                        title: "Access Point",
                        visible: true
                        title: "Permit Area",
                        // renderer: {
                        //     type: "simple",
                        //     symbol: {
                        //         style: "solid",
                        //         outline: {
                        //             style: "solid",
                        //             color: [255, 186, 0],
                        //             width: 1
                        //         color: [255, 186, 0, 0.2]
                        visible: true
                        title: "Access Route",
                        visible: true
                        title: "Walk-in Area",
                        visible: true
KenBuja
MVP Esteemed Contributor
Your code does work on this sample. Have you checked whether your layers support dynamic layers?
console.log(layer.capabilities.exportMap.supportsDynamicLayers);
You'll have to put this in the layer.when() function to ensure the layer is ready before you can see this property.
UgurcanErkal
Hi Ken, no, I didn't check that. But it looks like they does.
> rluLayer.capabilities.exportMap.supportsDynamicLayers
< true
> permitLayer.capabilities.exportMap.supportsDynamicLayers
< true
Noah-Sager
It would help to have a working app to debug. Are you getting any useful errors in the console? Did you verify that the MapServer supports dynamic layers from REST? E.g.
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer
UgurcanErkal
Hi Noah,
Yes, the MapServer supports dynamic layers. POT:
As for the error message, I attached it to the original post. I only see a Javascript exception but not an indicator of the cause.
