Is there an event when applyEdits - add / update features - Are ready, and visible on the map?
2133
12-01-2021 10:11 AM
AndrewMurdoch1
Good Day
Is there an event that will trigger once my updated / added features are visible on the map and ready for interaction?
Once the promise resolves ex:
layer.applyEdits({
    updateFeatures: data
}).then(() => {
    this.layerLoadedEvent.emit(true);
    r(null);
I'm still waiting for the features to be visible on the map, is there any event to let me know when everything is ready?
Thanks
BlakeTerhune
If you're looking for an event, try the edits event, which fires after applyEdits() is completed successfully. If you need to know when the layers are done drawing in the map, try watchUtils(). Here's some more info.
If you want to do something when the applyEdits() promise resolves, you should be able to do it in the .then like you have it there. Here's a sample.
BlakeTerhune
AndrewMurdoch1
That accomplished exactly what I'm looking for 🙂 - Thanks!
