Is there a way to take advantage of the 'suggest' of the World Geocoding Service?
2067
12-03-2014 02:05 PM
TracySchloss
Honored Contributor
I see there are some newer features in the REST API documentation for the World Geocoding Service.  I really like the idea of 'suggest' that lets the user to enter part of an address and get a list of suggested matches.
Is there a way to take advantage of this through the Javascript API, maybe through something like esri.request?
Tags (1)
StevenGraf1
var geocoder = new Geocoder({
    map: map,
autocomplete: true
  },"search");
The autocomplete:true property will give suggestions.  Is this what you were looking for?
StevenGraf1
    map: map,
autocomplete: true
  },"search");
TracySchloss
Honored Contributor
I've always used a locator task and not the geocoder dijit, because I always feel like I have more control with a task compared to the dijits.  I guess I need to give the dijit a 2nd look.
MattDriscoll
The locator task has a suggestLocations method which uses the locator suggest.
locator-amd | API Reference | ArcGIS API for JavaScript
TracySchloss
Honored Contributor
Maybe I should try that instead.  Going back through a geocoder dijit example,  I'm remembering what I didn't like about it in the first place - completely flaky behavior!  It will suggest my address, but when I select it to complete the navigation zoom etc, it's takes me instead to some other location entirely!  I know I will get nothing but complaints from the end users if I start using this instead.
