Is it possible to show the PopupTemplate of the last feature hovered on via "pointer-move"?
883
02-14-2024 06:38 AM
EmilyGoldsmith
Hello.
I have been exploring the sample code provided and noticed the Feature widget in a side panel example has a nice functionality which displays a pop-up template of the feature the user's cursor is currently hovering on.
However, one thing i've noticed is that, once the pointer is removed from hovering over the feature layer, the popuptemplate is reset and no pop-up displays.
I'm very new to hittests and the 'promiseUtils' function, so I was wondering if it were possible to configure the app to show the popuptemplate of the last feature hovered on?
Thank you.
LaurenBoyd
Hi @EmilyGoldsmith -
The logic for the sample just needs to be slightly modified. Instead of setting the Feature widget graphic to null if the hitTest doesn't return a graphic, you can just return and not do anything which will keep the highlight and Feature widget populated with the last viewed feature.
Here's the Feature widget sample with that modification on lines 95-97: https://codepen.io/laurenb14/pen/eYXbMXg?editors=1000
Hope this helps!
Lauren
LaurenBoyd
Hope this helps!
Lauren
EmilyGoldsmith
This is perfect, thank you!
