I'm currently working with POLYLINE, and I want to make a straight line and when I edit that line it shouldn't show 3 vertices. Having mid-point vertex, the user may move that vertex and the line will become polyline. Please help me with this one I am a beginner in ARCGIS javascript. Thank you
Hi there,
It cannot be done. However, you can disable the reshape operation while only leaving the transform operation enabled as shown below:
<SPAN class="keyword token">const</SPAN> sketch <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Sketch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> layer<SPAN class="punctuation token">:</SPAN> layer<SPAN class="punctuation token">,</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> creationMode<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"update"</SPAN><SPAN class="punctuation token">,</SPAN> defaultUpdateOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> toggleToolOnClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> tool<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"transform"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Here is a test app shows how it is done: https://codepen.io/U_B_U/pen/ExVBvZK?editors=1000
Hope this helps,
-Undral
Thank you!
