Incorrect sample code for labelling
1652
01-13-2025 12:39 PM
TedZhou
The sample code
https://developers.arcgis.com/javascript/latest/sample-code/layers-subtypegrouplayer/
seems to be incorrect.
If we change :
  item.layer.labelsVisible = true;
the labels are shown as below:
 ArcGIS users as us intend to learn what the following expression exactly means from ArcGIS team actually.
        labelExpression: "$feature.assetgroup"
The sample code just confused me.
ArcGIS team did great work.
Tags (1)
2 Solutions
KenBuja
MVP Esteemed Contributor
I think what the sample is doing is showing how to do different things with the layers. If you click the gear icon on a layer, the "Labels" button will show or hide the labels and the "unique" button will symbolize the data with a simple renderer or a unique-value renderer.
The labelExpression seems to be a mistake. If you replace that line with
labelExpressionInfo: {
  expression: "$feature.assetgroup"
the labels show unique information
If you find errors in the sample code, it's more helpful to give feedback directly to Esri about this. To do that, scroll to the bottom of the page and click the thumbs down icon. This will bring up a dialog to send a message to the team.
KenBuja
After a little more testing, you can also change it to this to get the same result
labelExpression: "[assetgroup]"
KenBuja
TedZhou
Thanks for your time and kind efforts.
KenBuja
TedZhou
That is a reasonable design. Thanks for your great assistance.
