Hello,I'm working on my second web mapping application, and I am implementing an identifyTask on a couple point layers that are scale-dependent. At first, the layers are disabled until the user zooms closer to the points. Eventually, the points are re-enabled because the current scale meets the scale criteria. If I turn on one of the n layers and attempt to identify an area around the point, my identifyTask will identify the layer that's turned on and the layers that are turned off. I believe this is a bug of some sort. My code is below:identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [1,2,3,4,5,6,7,9];
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
identifyParams.geometry = geometry;
identifyParams.mapExtent = map.extent;
identifyParams.width = map.width;
identifyParams.height = map.height;
identifyTask.execute(identifyParams, function (identifyResults) {
If I were to output identifyResults to the console, it would contain the visible and non-visible layers. As you can see, I specified LAYER_OPTION_VISIBLE, so it should only be identifying layers that are turned on, not the ones that are enabled due to scale dependency! I'm using 3.2compact as my API.Thanks,Andrew
