Icon Glitch on Refresh FeatureLayer
1715
03-19-2024 09:51 AM
fb1
out of necessity I had to load the arcgis js sdk locally,
and I noticed a problem that I didn't have before and that I couldn't solve,
in a nutshell I have 3 featurelayers on the same zoom level,
one is a shapefile so let us not consider it, and the other two are derived from a geojson with points .
Both featurelayers have a refresh rate of about 10 seconds,
depending on how these two are loaded the last one has a strange glitch at refresh which the other one does not.
A black rectangle appears on the icon for a fraction of a second, which is very annoying.
fb1
The problem was the version of angular and related libraries (angular 15, zone.js 0.13.0 etc.).
after updating angular to version 17 I no longer had any problems
fb1
without taking into account the third layer of the shapefile i noticed that leaving only one of the two layers active with the icons does not cause this problem, so when I go to put the second layer back on, it starts glitching again
fb1
