I want to put an arc on the ground (3D map) and let it rotate slowly, how can I do it?
1165
03-25-2023 07:20 PM
tangms
I wana put an arc graphic on the ground (3D map) and let it rotate slowly, how can I do it?
I'm using argis js 4.19,I want a smooth aninams ,so I cannot delete layer and add layer. this would let screen blink! could u help me?
JamesIng
It's not really built for animation in that sense but you can effectively create what your after by creating  a graphic and then creating your own animation frameHandler by using something like a setInterval() that regular updates the geometry of that graphic.
A really quick rough example that I modified from the code sample looks like:
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>
      Add Graphics to a SceneView | Sample | ArcGIS Maps SDK for JavaScript 4.26
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.26/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.26/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/layers/GraphicsLayer",
        "esri/Graphic",
        "esri/geometry/geometryEngine"
      ], (Map, SceneView, GraphicsLayer, Graphic, geometryEngine) => {
        const map = new Map({
          basemap: "hybrid"
        const view = new SceneView({
          container: "viewDiv",
          map: map,
          camera: {
            // autocasts as new Camera()
            position: {
              // autocasts as new Point()
              x: -0.17746710975334712,
              y: 51.44543992422466,
              z: 1266.7049653716385
            heading: 0.34445102566290225,
            tilt: 82.95536300536367
         * Add graphics layer
        const graphicsLayer = new GraphicsLayer();
        map.add(graphicsLayer);
         * Add a 3D point graphic
        // London
        const point = {
          type: "point", // autocasts as new Point()
          x: -0.178,
          y: 51.48791,
          z: 1010
        const markerSymbol = {
          type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
          color: [226, 119, 40],
          outline: {
            // autocasts as new SimpleLineSymbol()
            color: [255, 255, 255],
            width: 2
        const pointGraphic = new Graphic({
          geometry: point,
          symbol: markerSymbol
        graphicsLayer.add(pointGraphic);
         * Add a 3D polyline graphic
        const polyline = {
          type: "polyline", // autocasts as new Polyline()
          paths: [
            [-0.178, 51.48791, 0],
            [-0.178, 51.48791, 1000]
        const lineSymbol = {
          type: "simple-line", // autocasts as SimpleLineSymbol()
          width: 4
        const polylineGraphic = new Graphic({
          geometry: polyline,
          symbol: lineSymbol
        graphicsLayer.add(polylineGraphic);
         * Add a 3D polygon graphic
        const polygon = {
          type: "polygon", // autocasts as new Polygon()
          rings: [
            [-0.184, 51.48391, 400],
            [-0.184, 51.49091, 500],
            [-0.172, 51.49091, 500],
            [-0.172, 51.48391, 400],
        const fillSymbol = {
          type: "simple-fill", // autocasts as new SimpleFillSymbol()
          color: [227, 139, 79, 0.8],
          outline: {
            width: 2
        const polygonGraphic = new Graphic({
          attributes: {
            title: "square"
          geometry: polygon,
          symbol: fillSymbol
        graphicsLayer.add(polygonGraphic);
        view.when(() => {
          let timerControl = setInterval(() => {
            const toRotate = graphicsLayer.graphics.items.find(graphic => graphic.attributes?.title === 'square')
                const rotatedGeometry = geometryEngine.rotate(toRotate.geometry, 2)
                toRotate.geometry = rotatedGeometry;
          }, 100);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
The key part being this:
          }, 100);
Where I'm running a function every 100ms that calls geometryEngine to rotate a geometry by 2 degrees.
James from www.landkind.com
tangms
that's work  for me,thank u!
