I can't over zoom tiles of tiledlayer despite setting maxScale to 0
1605
03-17-2022 01:07 AM
YObaidat
I want to over zoom tiled layer tiles by setting maxScale to 0 but still I can't zoom beyond specific scale. You can check code below. Please note that when try to do the same with JS Api v3 it works. What I'm missing here if anyone could help please.
 https://codepen.io/yobeidat/pen/KKZVPKE
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>
      Intro to MapImageLayer | Sample | ArcGIS API for JavaScript 4.22
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.22/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.22/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/MapImageLayer",
        "esri/layers/TileLayer",
        "esri/Basemap"
      ], (Map, SceneView, MapImageLayer,TileLayer,Basemap) => {
  let baseLayer = new TileLayer({
    url: "https://services.arcgisonline.com/arcgis/rest/services/World_Terrain_Base/MapServer",
    maxScale:0
  let basemap = new Basemap({
  baseLayers: [
    baseLayer
        const permitsLayer = new MapImageLayer({
          portalItem: {
            // autocasts as new PortalItem()
         * Add the layer to a map
        const map = new Map({
          basemap: basemap,
          layers: [permitsLayer]
        const view = new SceneView({
          container: "viewDiv",
          map: map
        permitsLayer.when(() => {
          view.goTo(permitsLayer.fullExtent).catch((error) => {
            if (error.name != "AbortError") {
              console.error(error);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
ReneRubalcava
Esri Frequent Contributor
Try the solution mentioned here, because you are dealing with tiles, you need to define the lods as well.
https://community.esri.com/t5/arcgis-api-for-javascript-questions/allow-over-zoom-in-map-view/m-p/10...
YObaidat
YObaidat
@ReneRubalcava ,Could you please help me with this issue?
ReneRubalcava
YObaidat
Thank you setting lods: TileInfo.create().lods, in constrains object solved my problem
