How to show zoom level at the bottom of the map when the user zooms in and out?
2507
07-22-2020 12:31 AM
SiyabongaKubeka
Hi All,
I have an Esri map, what I want to do with it is to show the zoom level at the bottom or anywhere in the map when the user zooms in or out. How can I do that? Below is the sample of the map that I am using.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>DEA GIS APPLICATION</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.12/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/widgets/Sketch",
        "esri/Map",
        "esri/layers/GraphicsLayer",
        "esri/views/MapView"
      ], function(Sketch, Map, GraphicsLayer, MapView) {
        const layer = new GraphicsLayer();
        const map = new Map({
          basemap: "streets",
          layers: [layer]
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 5,
          center: [90, 45]
        const sketch = new Sketch({
          layer: layer,
          view: view,
          availableCreateTools: ["point"]
        view.ui.add(sketch, "top-right");
        sketch.on('create', function(evt){
                                           console.log("X = ", evt.graphic.geometry.x);
                                           console.log("Y = ", evt.graphic.geometry.y);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Kind Regards
Siyabonga Kubeka
0761040911
Egge-Jan_Pollé
Hi Siyabonga Kubeka,
You may use watchUtils to capture the zoom level when the view becomes stationary, and then add this value to your map. Like this:
watchUtils.whenTrue(view, "stationary", function() {
  lon = parseInt(view.center.x); // with parseInt values are rounded to the full meter (coordinates in Web Mercator - EPSG:3857)
  lat = parseInt(view.center.y);
  zoomLevel = view.zoom;
  document.getElementById("location").innerHTML = "Map Center - Longitude: " + lon + " / Latitude: " + lat + " / Zoom level: " + zoomLevel;
HTH,
Egge-Jan
Here is the full solution:
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>ArcGIS JavaScript Tutorials: show zoom level</title>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #location {
      padding: 15px;
      background: white;
      color: black;
       border: 5px solid gold;
       font-family: sans-serif;
       font-size: 1.2em;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.16/esri/css/main.css">
  <script src="https://js.arcgis.com/4.16/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/core/watchUtils"
    ], function(Map, MapView, watchUtils) {
      var map = new Map({
        basemap: "streets"
      var view = new MapView({
        map: map,
        center: [90, 45], // longitude, latitude
        zoom: 5
      view.ui.add("location", "bottom-left");
  </script>
</head>
<body>
  <div id="location"></div>
</body>
</html>
Egge-Jan_Pollé
HTH,
Egge-Jan
<html>
<head>
  <style>
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #location {
      padding: 15px;
      background: white;
      color: black;
       font-size: 1.2em;
  </style>
  <script>
    require([
      "esri/Map",
      var map = new Map({
        basemap: "streets"
        map: map,
        zoom: 5
  </script>
</head>
<body>
</body>
</html>
SiyabongaKubeka
Hi Egge-Jan,
Thank you very much. Much appreciated. It works.
Kind Regards
Siyabonga Kubeka
