Hi All,
I have an Esri map, what I want to do with it is to show the zoom level at the bottom or anywhere in the map when the user zooms in or out. How can I do that? Below is the sample of the map that I am using.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>DEA GIS APPLICATION</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.12/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/widgets/Sketch",
"esri/Map",
"esri/layers/GraphicsLayer",
"esri/views/MapView"
], function(Sketch, Map, GraphicsLayer, MapView) {
const layer = new GraphicsLayer();
const map = new Map({
basemap: "streets",
layers: [layer]
const view = new MapView({
container: "viewDiv",
map: map,
zoom: 5,
center: [90, 45]
const sketch = new Sketch({
layer: layer,
view: view,
availableCreateTools: ["point"]
view.ui.add(sketch, "top-right");
sketch.on('create', function(evt){
console.log("X = ", evt.graphic.geometry.x);
console.log("Y = ", evt.graphic.geometry.y);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Kind Regards
Siyabonga Kubeka
0761040911
