How to show the sublayer of tileLayer
1363
12-26-2023 02:00 AM
AbramhumHsu
I meet a problem when using tileLayer.
I got this error message:[esri.views.LayerViewFactory] Failed to create view for layer 'Layer, id:18ca58dcb5d-layer-1' of type 'tile'.
and in mapserver description page, I see these infos:
is this mean I should get the map data from sublayer, and further more, how to make it, thanks a lot.
Noah-Sager
Hi @AbramhumHsu, can you share your code? Here is an example of using a TileLayer from a MapServer URL:
https://codepen.io/noash/pen/PoLqqNv?editors=1000
Noah-Sager
AbramhumHsu
This is great, I use the codes as the document description, but it invalid.
1.
let serviceSublayers = newBasemap.createServiceSublayers();
newBasemap.sublayers = serviceSublayers;
2.
let result = newBasemap.sublayers;
let newBasemap2 = newBasemap.findSublayerById(1);
newBasemap is built via tileLayer, it seems tileLayer is not used for sublayers, thanks.
