I asked a similar question on GIS SE the other day:
Incorrect time displaying in ArcGIS Javascipt popup template
The answer I got worked great for when I was using the PopupTemplate, but I've since switched to using the TooltipDialog or Info Window.
In ArcMap, I have a field called ReadTime of Date data type, and it shows the value:
6/17/2015 2:58:35 PM
I'm using the following formatting for the TooltipDialog:
"<b>Read Time: </b>${ReadTime:DateFormat(datePattern: 'M/d/yyyy hh:mm:ss a', selector:'date')}"
The problem is that in the web map I'm getting the following value:
6/17/2015 7:58:35 AM
So, the time is showing as 7 hours behind.
Is there a similar way I can set the UTC offset to 0, like when I used the PopupTemplate?
