How to load basemap with language chinese to SceneView, like https://www.arcgis.com/home/webscene/viewer.html ?
You can find a gallery of the available base maps in this blog post:
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/whats-new-in-esri-vector-basemaps-february-2019/
Looks like they have base maps for Chinese (Hong Kong), Chinese (Taiwan) and Modern Chinese. In the snippet below I use the base map id for one of the Chinese base maps and set it as the map's base map.
<SPAN class="keyword token">var</SPAN> id <SPAN class="operator token">=</SPAN> <SPAN class="string token">"7507c43a3cee4aa282453a11e9be62fc"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Basemap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> portalItem<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN>id <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> ground<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"world-elevation"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Eric,
You can use an Esri vector basemap found here:
There are 3 choices for Chinese (Hong Kong, Taiwan, and Modern)
Thank you very much! It's solved!
