how to get click or checked event for Radio button inside a popup window
1034
05-22-2022 04:50 AM
NadirHussain
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>Identify | Sample | ArcGIS API for JavaScript 4.23</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-popup .esri-popup-header .esri-title {
font-size: 18px;
font-weight: bolder;
.esri-popup .esri-popup-body .esri-popup-content {
font-size: 14px;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.23/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.23/"></script>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/MapImageLayer",
"esri/rest/identify",
"esri/rest/support/IdentifyParameters"
], function (Map, MapView, MapImageLayer, identify, IdentifyParameters) {
var params;
// URL to the map service where the identify will be performed
var identifyURL =
"https://sampleserver6.arcgisonline.com/arcgis/rest/services/MtBaldy_BaseMap/MapServer";
// Add the map service as a MapImageLayer
// use identify to query the service to add interactivity to the app
var identifyLayer = new MapImageLayer({
url: identifyURL,
opacity: 0.5
var map = new Map({
basemap: "osm"
map.add(identifyLayer);
var view = new MapView({
map: map,
container: "viewDiv",
center: [-117.23502, 34.23911],
zoom: 13
view.when(function () {
// executeIdentify() is called each time the view is clicked
view.on("click", executeIdentify);
// Set the parameters for the identify
params = new IdentifyParameters();
params.tolerance = 3;
params.layerIds = [0, 1, 2, 3, 4];
params.layerOption = "All";
params.width = view.width;
params.height = view.height;
// Executes each time the view is clicked
function executeIdentify(event) {
// Set the geometry to the location of the view click
params.geometry = event.mapPoint;
params.mapExtent = view.extent;
document.getElementById("viewDiv").style.cursor = "wait";
// This function returns a promise that resolves to an array of features
// A custom popupTemplate is set for each feature based on the layer it
// originates from
identify
.identify(identifyURL, params)
.then(function (response) {
var results = response.results;
return results.map(function (result) {
var feature = result.feature;
var layerName = result.layerName;
feature.attributes.layerName = layerName;
 if (layerName === "Landuse") {
feature.popupTemplate = {
// autocasts as new PopupTemplate()
title: layerName,
content:
"<b>Block ID:</b> {BLOCK_ID} " +
"<br><b>Geometry Type:</b> {Shape}" +
"<br><b>Landuse Area:</b> {Shape_Area}"+
"<br><label for=rdComp >اسم الشركة</label><input type=radio id= rdComp name=rdGroup value=Comp checked=checked></><br>"
return feature;
.then(showPopup); // Send the array of features to showPopup()
// Shows the results of the identify in a popup once the promise is resolved
function showPopup(response) {
if (response.length > 0) {
view.popup.open({
features: response,
document.getElementById("viewDiv").style.cursor = "auto";
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
when user click i want to check the status of radio button.please help.i am using 4.23 arcgis api.
