How to change the radius of the circle around the marker using javascript Arcgis?
5704
11-12-2014 08:42 AM
ManjariGoyal
I am trying to create a buffer based on the drop down box radius value. so far I tried two different things but none of them working.
First try:
var circle;
        var radius = parseInt(dom.byId("Radius").value);
        function Buffer(evt){
          console.log(evt);
              circle = new Circle({
                center: evt,
                geodesic: true,
                radius: radius
                radiusUnit: "esriMiles"
          //map.graphics.clear();
          map.infoWindow.hide();
          var graphic = new Graphic(circle, circleSymb);
          map.graphics.add(graphic);
Second try:
var circle;
          console.log(evt);
            var selectedRadius = (document.getElementById("Radius"), 'change', function(){
            circle.setRadius(document.getElementById('Radius').value)
                center: evt,
                geodesic: true,
                radius: "selectedRadius"
HTML Part: creates a drop down box
Choose the radius in Miles
      <select id="Radius">
      <option selected="selected">1 Mile</option>
          <option>2 Miles</option>
          <option>3 Miles</option>
          <option>4 Miles</option>
          <option>5 Miles</option>
          </select>
RobertScheitlin__GISP
Manjari,
   Would the value of your Radius select component not be "2 Miles"? How will that be parsed into an int? You need your returned value to only have the integer portion of the selected value before you attempt to parse it to an integer.
var strVal = dom.byId("Radius").value;
var radius = parseInt(strVal.replace(' Miles', ''));
OR better yet define a value attribute in your options list:
      <option selected="selected" value="1">1 Mile</option>
      <option value="2">2 Miles</option>
      <option value="3">3 Miles</option>
      <option value="4">4 Miles</option>
      <option value="5">5 Miles</option>
</select>
and then use this code:
dom.byId("Radius").options[dom.byId("Radius").selectedIndex].value;
ManjariGoyal
Robert,
It does make sense and I tried it again but still it's not creating a buffer/draw a circle of specified radius.
Manjari,
  Here is a full working sample:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title></title>
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
      #controls {
        background: #fff;
        box-shadow: 0 6px 6px -6px #999;
        color: #444;
        font-family: sans-serif;
        height: auto;
        left: 1em;
        padding: 1em;
        position: absolute;
        top: 1em;
        width: auto;
        z-index: 40;
      #controls div {
        padding: 0 0 1em 0;
    </style>
    <script src="//js.arcgis.com/3.11/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/geometry/Circle", "esri/symbols/SimpleFillSymbol",
        "esri/graphic", "esri/layers/GraphicsLayer",
        "dojo/dom", "dojo/dom-attr", "dojo/domReady!"
      ], function(
        Map, Circle, SimpleFillSymbol,
        Graphic, GraphicsLayer,
        dom, domAttr
        map = new Map("map", {
          basemap: "streets",
          center: [-120.741, 56.39],
          slider: false,
          zoom: 6
        var symbol = new SimpleFillSymbol().setColor(null).outline.setColor("blue");
        var gl = new GraphicsLayer({ id: "circles" });
        var geodesic = dom.byId("geodesic");
        map.addLayer(gl);
        map.on("click", function(e) {
          var radius = dom.byId("Radius").options[dom.byId("Radius").selectedIndex].value;
          var circle = new Circle({
            center: e.mapPoint,
            geodesic: domAttr.get(geodesic, "checked"),
            radius: radius,
          var graphic = new Graphic(circle, symbol);
          gl.add(graphic);
    </script>
  </head>
  <body>
    <div id="map"></div>
    <div id="controls">
        <option selected="selected" value="5">5 Mile</option>
        <option value="10">10 Miles</option>
        <option value="20">20 Miles</option>
        <option value="30">30 Miles</option>
        <option value="40">40 Miles</option>
      </select>
      <input type="checkbox" id="geodesic">
      <label for="geodesic">Geodesic?</label>
    </div>
  </body>
</html>
ManjariGoyal
Thanks Robert.
