How to change the color of zoom border when its click?
1704
01-04-2022 05:06 PM
altair
please use this as a example
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=intro-mapview
and im notice that its different, `+` icon and `-` icon highlighting are different, how do i align them like how do i align the - icon?
BlakeTerhune
MVP Frequent Contributor
Not sure if there's a better way, but you can add this to your CSS
.esri-zoom .esri-widget--button:first-child {
    margin-bottom: 2px;
RickeyFight
MVP Regular Contributor
@altair
You could use CSS. Here I changed it to red.
NateMurry_NOAA
Greetings Rickey:
I am rather new at JS API development, so please forgive any ignorance on my part.
Your answer makes sense to me if you are modifying the CSS file for a local instance of the JS API.  (I found these lines in ESRI's online version of the API, which I assume is read-only).  However, if you are not using a local instance of the JS API, which CSS file are you operating on to apply these changes?  Thank you for your time.
--NMM
RickeyFight
@NateMurry_NOAA
How are you planning to deploy this? With a custom webapp? Like with the sample script you linked to?
BlakeTerhune
    margin-bottom: 2px;
