How to change position of Zoom and Search widget in 4.11
6818
04-18-2019 11:58 AM
tonyko
Is there a way that I can specify the top and left css positions of either of these widgets. It seems as though there was a way in 3.28 but I can't seem to make it work in 4.11.
I only see the generic positions I can add: "top-trailing", "top-left"
KellyHutchins
Esri Notable Contributor
You can use the manual option and provide the position via css. There's an example here: JS Bin - Collaborative JavaScript Debugging
BirajaNayak
Hi Tony,
You can add UI position as per below:
Possible Values: bottom-leading | bottom-left | bottom-right | bottom-trailing | top-leading | top-left | top-right | top-trailing | manual
Here are the web help links:
https://developers.arcgis.com/javascript/latest/guide/view-ui/
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-ui-UI.html#add
Example:
view.ui.add(search, "top-right");
Biraja
tonyko
I'm looking for the proper way to position it using pixels. NOT by using the defaults they provide
KellyHutchins
