How To Add hyperlinks to the footer of a pop-up window using ArcGIS API for JavaScript 4.18 ?
2294
03-16-2021 08:57 AM
Med-Karim-Rouissi
Hey everyone,
I'm trying to use this code with Arcgis JS 4.18, but according to ESRI support this code works only for 3.x versions.
https://support.esri.com/en/technical-article/000014528
Code:
var link = domConstruct.create("a",{
 "class": "action",
 "id": "statsLink",
 "innerHTML": "More Information", //the text representing the link
 "href": "javascript: void(0);"
 }, query(".actionList",map.infoWindow.domNode)[0]);
 on(link, "click", [function name]);
function cp(evt){
 window.open("http://url"); //set the url to be displayed
as seen in these two examples:
https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=exp_history
https://developers.ardomNodejavascript/3/sandbox/sandbox.html?sample=gp_popuplink
KenBuja
MVP Esteemed Contributor
You can add an action to the popup that will appear in the footer. Your action could open a new browser window with your link.
See this sample, although it's currently broken. You have to make one change in the sandbox version. Change line 47 to this
url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/OpenBeerDB/FeatureServer/0",
and click on a brewery with a website (not all of them have one). The popup contains a new icon that, when clicked, opens the link.
KenBuja
Med-Karim-Rouissi
I understood , i plan to add a link in the popup to a related feature-layer that I have already requested, is it possible to do so by customizing this example?
