How I can display multiple points in a map from an array ?
3208
01-02-2021 11:14 PM
Abdulmajeed__
Hi everyone
I want to display multiple points in a map using array
here is my code
<html>
  <head>
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title>ArcGIS API for JavaScript Tutorials: Create a JavaScript starter app</title>
    <style>
      html, body, #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
     <link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
     <script src="https://js.arcgis.com/4.15/"></script>
     <script>
     // My Array
var locs = ["51.38254, -2.362804", "51.235249, -2.297804", "51.086126, -2.210767"]
         require([
      "esri/Map",
      "esri/views/MapView",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/Multipoint",
      "esri/layers/FeatureLayer",
  "esri/geometry/Point",
  "dojo/domReady!"
    ], function(Map, MapView, Graphic, GraphicsLayer,
    Point) {
          var map = new Map({
            basemap: "dark-gray"
          var view = new MapView({
            container: "viewDiv",
            map: map,
            center: [46.738586,24.774265], // longitude, latitude
            zoom: 6
          var graphicsLayer = new GraphicsLayer();
       map.add(graphicsLayer);
      // create a point
       var Point ={
        type: "point",
        longitude: 48.738586,
         latitude: 24.774265
       var simpleMarkerSymbol = {
         type: "simple-marker",
         color: [46, 204, 113 ],  // Green
         outline: {
           color: [255, 255, 255], // white
           width: 1
       //*** ADD ***//
      // Create attributes
      var attributes = {
        Name: "My point",  // The name of the
        Location: " Point Dume State Beach",  // The owner of the
      // Create popup template
      var popupTemplate = {
        title: "{Name}",
        content: "Test <b>{Location}</b>."
      var pointGraphic = new Graphic({
        geometry: Point,
        symbol: simpleMarkerSymbol,
        //*** ADD ***//
        attributes: attributes,
        popupTemplate: popupTemplate
      graphicsLayer.add(pointGraphic);
        </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
ManishPatel
Hi @Abdulmajeed__ ,
Please see the below link, this should give you a good idea.
Note, that the points are currently, located in the ocean, it could be depending on the coordinates.
https://codepen.io/patelmanya/pen/dypmjJE?editors=1000
Cheers,
Manish
ManishPatel
Hi @Abdulmajeed__ ,
Cheers,
Manish
