How esri.bundle is loaded? Object missing.
4310
12-03-2013 10:13 AM
ZachLiu1
I have  an app and I want to change the drawToolbar tooltips.
So I tried to change esri.bundle.toolbars.draw, but for some reason, I got an undefined error.
I checked the browser console and there is not object bundle under esri namespace.
I found some really old posts about this issue but no answers found.
Anyone has a clue?
JeffPace
are you using AMD?
require "dojo/i18n!esri/nls/jsapi"
function(esriBundle)
esriBundle.toolbars.draw.finish = "Double-click to finish";
JeffPace
are you using AMD?
ZachLiu1
It is exactly what I am looking for.
It is a little wired because I can use esri.bundle.toolbars in many similar apps without problems.
Also I tried to find it in API reference but it seems it is not documented there.
Saved the day, thanks Jeff!
JeffPace
happy to help
here is the (admittedly obscure) documentation
https://developers.arcgis.com/en/javascript/jshelp/inside_bundle.html
BenFousek
It's strange that esri.bundle would be undefined. The full api and compact should load esri.bundle based on your locale automatically every time. It's a component of the api creating the esri namespace.  Without it there are no string values for anything the api does involving the display of text.
Jeff - thanks for pointing out that obscure documentation.  Need to backtrack on a couple items I thought were wrapped up.
