John/Mike,Thanks for responding. My table is located in a FileGeoDatabase so I can certainly publish it via ArcGIS Server. How do I publish JUST the table in ArcGIS Server? I tried adding the table to a blank MXD and publishing the MXD but the table isn't listed in the published service.Worst comes to worse, I could add the table into another existing map service and then access it through that service but I'd like to know how to publish a stand alone table.
Hi Steve,
I found this thread when I encountered the same issue.
There has been a NIM logged for the ability to publish a standalone table as a service: NIM084140 - Unable to share a map containing only a stand-alone table as service.
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDg0MTQw
Like you said, the current workaround is publish map document with table and include an empty, unchecked feature class and then will be able to publish/query the table as REST.
I had a customer with a similar issue,
What I did to resolve this
Turn the nonspatial table into a Feature Class with a 'dummy' point
Publish the service with WFS enabled
Using the Interopablity Connection I managed to view the Attribute Table Successfully in the map.
Signed in members can post, follow updates, and more. New here? Register a free account.
