Highlighting country by country name (and not by tapping on the map)
1166
06-13-2022 08:38 AM
ericca
Good day,
I have these two requirements:
  1. Tapping a country (or multiple countries) on a map highlights the country and selects rows for that country on a data grid.
  2. Tapping on the data grid selects the row and highlights the country (of the selected row) on the map.
I'm able to achieve requirement #1 with the codes specified in - https://developers.arcgis.com/javascript/latest/sample-code/effect-blur-shadow/
But for #2, I can't seem to find an api that will accept country name of country fid nor any post about this.
The code in the link uses:
var query = {
   geometry: view.toMap(event),
   returnGeometry: true,
   outFields: ["*"]
featureLayer.queryFeatures(query);
But on the next requirement, the input country will be from the selected row and not a coordinate from the map.
Anyone know if there's another API for this or if this is possible?
Here's my test page -
Thanks!
ericca
Hi Jill,
I'm using a regular html table which displays business data.
I was able to resolve the requirement above though using Query object. Here's a sample code:
queryObject = new Query();
queryObject.where = "COUNTRY = '" + selectedCountry + "'";
queryObject.returnGeometry = true;
queryObject.outFields = ["*"];
query.executeQueryJSON(queryUrl, queryObject).then(function (results) {
	if (results.features) {
		graphicsLayer.graphics.add(results.features[0]);
Thanks!
JillianStanford
Are you using the FeatureTable widget?
This sample demonstrates how to select a feature using the map or the table -
FeatureTable widget with a map
Jill
ericca
Hi Jill,
Thanks!
