Hiding 'groupness' of TileLayers inside Layerlist
2025
02-01-2023 01:17 AM
LeidavanHees
Hello,
I have a layerList with legend that works beautifully for normal layers and groups. But I'd like it to show tileLayers as normal layers instead of groups.
Currently it does this (only "Groen" is a group, the rest are tileLayers):
It looks the same if I open the map in the esri map viewer:
Is there any way for me to change this so that the tileLayers do not have the arrow to open them? Or should I just not work with tileLayers?
Any help would be much appreciated!
Sage_Wall
I haven't tested the code below but I think something like this would work to loop through the webmap's layers and if the layer type is "tile" then set the listMode to "hide-children".  If I get a chance later today I'll try to work up a working example.
const webmaps = webmapids.map((webmapid) => {
    const webmap = new WebMap({
        portalItem: {
    // wait for the webmap to load
    webmap.when(() => {
        webmap.layers.forEach( (layer) => {
            if (layer.type === "tile") {
                layer.listMode = "hide-children"
    return webmap;
Sage_Wall
Hi @LeidavanHees ,
You can hide the sublayers with the listMode property set to "hide-children" on the layer.
const layer = new TileLayer({
    url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer",
    listMode: "hide-children"
 https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-TileLayer.html#listMode
LeidavanHees
Thanks for your response @Sage_Wall. I think I'm missing something though.
I don't make any layers in my app, I just load a webmap that happens to have TileLayers in it:
		const webmapids = [
			"146f547ab7654d71a38d3a55654d56c2",
			"a744f367411a43a9bb75072926d79e6f"
			return new WebMap({
				portalItem: {
					// autocasts as new PortalItem()
Is there a way to do this still?
Sage_Wall
        portalItem: {
    webmap.when(() => {
    return webmap;
LeidavanHees
That works like an absolute charm, thank you very much!
LeidavanHees
I case anyone needs this in the future. It works even better when using allLayers instead of layers:
        portalItem: {
    webmap.when(() => {
        webmap.allLayers.forEach( (layer) => {
    return webmap;
Since that also fixes it for any tileLayers inside of groupLayers
