Hide edit text symbol editor
3348
10-03-2014 01:12 PM
VygintasCesnauskas
Is it possible to hide the pop-up dialog that appears when editToolbar.activate(Edit.EDIT_TEXT...) is activated?
Vara_PrasadM_S
Hi Vygintas,
There is a property "textSymbolEditorHolder", which can be set in "options" list of parameters in the constructor of Edit Tool bar.
1. Include one div element in your html and set display as none for style, as below.
<div id="txtSymbolEditorHolder" style="display: none;"></div>
2. Then, specify the id of this div element as value for the property "textSymbolEditorHolder", as below
var options = {
                  allowAddVertices: registry.byId("vtx_ca").checked,
                  allowDeleteVertices: registry.byId("vtx_cd").checked,
                  uniformScaling: registry.byId("uniform_scaling").checked,
                  textSymbolEditorHolder: "txtSymbolEditorHolder"
Then, the symbol editor will not be displayed. below is the updated code of the sampe you mentioned which does not display the symbol editor.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>
      Edit Tools
    </title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/nihilo/nihilo.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body, #mainWindow {
        font-family: sans-serif;
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #mainWindow {
        visibility: hidden;
    </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
        var map, editToolbar;
        require([
        "esri/map",
        "esri/toolbars/edit",
        "esri/graphic",
        "esri/geometry/Point",
        "esri/geometry/Polyline",
        "esri/geometry/Polygon",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/TextSymbol",
        "dojo/_base/event",
        "dojo/parser",
        "dojo/dom",
        "dojo/dom-style",
        "dijit/registry",
        "dijit/Menu",
        "dijit/form/ToggleButton",
        "dijit/form/DropDownButton",
        "dijit/CheckedMenuItem",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function (
        Map, Edit, Graphic,
        Point, Polyline, Polygon,
        SimpleLineSymbol, SimpleFillSymbol, TextSymbol,
        event, parser, dom, domStyle, registry, Menu
          parser.parse();
          domStyle.set(registry.byId("mainWindow").domNode, "visibility", "visible");
          map = new Map("map", {
              basemap: "streets",
              center: [3.955, 59.338],
              zoom: 3
          map.on("load", createToolbar);
          function createToolbar() {
              addGraphics();
              editToolbar = new Edit(map);
              //Activate the toolbar when you click on a graphic
              map.graphics.on("click", function (evt) {
                  event.stop(evt);
                  activateToolbar(evt.graphic);
              //deactivate the toolbar when you click outside a graphic
              map.on("click", function (evt) {
                  editToolbar.deactivate();
          function addGraphics() {
              //add pre-defined geometries to map
              var polygonSymbol = new SimpleFillSymbol();
              var polylineSymbol = new SimpleLineSymbol();
              var text = new TextSymbol("Editable Text");
              text.font.setSize("20pt");
              var polyline = new Polyline({
                  "paths": [
                [-12484306, 7244028],
                [-7318386, 10061803],
                [-3013453, 10727111]
            ], "spatialReference": {
                "wkid": 102100
              var polygon = new Polygon({
                  "rings": [
                [-4226661, 8496372],
                [-3835304, 8731187],
                [-2269873, 9005137],
                [-1213208, 8613780],
                [-1017529, 8065879],
                [-1213208, 7478843],
                [-2230738, 6891806],
                [-2935181, 6735263],
                [-3522218, 6891806],
                [-3952711, 7165757],
                [-4265797, 7283164],
                [-4304933, 7635386],
                [-4304933, 7674521],
                [-4226661, 8496372]
                      "wkid": 102100
              var arrow = new Polygon({
                  "rings": [
                [9862211, 6617856],
                [8922952, 5522055],
                [8922952, 5991684],
                [6105178, 5991684],
                [6105178, 7087485],
                [8922952, 7087485],
                [8922952, 7557114],
                [9862211, 6617856]
                      "wkid": 102100
              var triangle = new Polygon({
                  "rings": [
                [2426417, 8535508],
                [4304933, 12292541],
                [6183449, 8535508],
                [2426417, 8535508]
                      "wkid": 102100
              var point = new Point(-40, 35);
              map.graphics.add(new Graphic(polyline, polylineSymbol));
              map.graphics.add(new Graphic(polygon, polygonSymbol));
              map.graphics.add(new Graphic(arrow, polygonSymbol));
              map.graphics.add(new Graphic(triangle, polygonSymbol));
              map.graphics.add(new Graphic(point, text));
          function activateToolbar(graphic) {
              var tool = 0;
              if (registry.byId("tool_move").checked) {
                  tool = tool | Edit.MOVE;
              if (registry.byId("tool_vertices").checked) {
                  tool = tool | Edit.EDIT_VERTICES;
              if (registry.byId("tool_scale").checked) {
                  tool = tool | Edit.SCALE;
              if (registry.byId("tool_rotate").checked) {
                  tool = tool | Edit.ROTATE;
              // enable text editing if a graphic uses a text symbol
              if (graphic.symbol.declaredClass === "esri.symbol.TextSymbol") {
                  tool = tool | Edit.EDIT_TEXT;
              //specify toolbar options
              var options = {
              editToolbar.activate(tool, graphic, options);
    </script>
  </head>
  <body class="nihilo">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:'false'">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:58px;text-align:left;font-weight:bold;font-size:14px;color:#400D12;">
      <span>Specify options then click a graphic to edit the shape. Click outside the graphic to deactivate the toolbar.</span><br />
      <div id="tool_move" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Move</div>
      <div id="tool_vertices" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Edit Vertices</div>
      <div id="tool_scale" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Scale</div>
      <div id="tool_rotate" data-dojo-type="dijit/form/ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Rotate</div>
      <button data-dojo-type="dijit/form/DropDownButton" id="options"  data-dojo-props="value:'options'">
        <span>Options</span>
        <div data-dojo-type="dijit/Menu" id="optionsMenu">
          <div id="vtx_ca" data-dojo-type="dijit/CheckedMenuItem" data-dojo-props="checked:'true'">Allow Add Vertices</div>
          <div id="vtx_cd" data-dojo-type="dijit/CheckedMenuItem" data-dojo-props="checked:'true'">Allow Delete Vertices</div>
          <div id="uniform_scaling" data-dojo-type="dijit/CheckedMenuItem" data-dojo-props="checked:'true'">Uniform Scaling when Resizing</div>
        </div>
      </button>
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
    </div>
    </div>
  </body>
</html>
Please let me know if it helped.
Thanks & Regards,
Vara Prasad.
Vara_PrasadM_S
Hi Vygintas,
Is it possible for you to provide any sample application?
Thanks & Regards,
Vara Prasad.
VygintasCesnauskas
Hi Vara,
This sample has the above mentioned functionality https://developers.arcgis.com/javascript/jssamples/toolbar_edit.html
Vara_PrasadM_S
Hi Vygintas,
var options = {
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <title>
      Edit Tools
    </title>
    <style>
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #mainWindow {
        visibility: hidden;
    </style>
    <script>
        require([
        "esri/map",
        "esri/graphic",
        "dojo/_base/event",
        "dojo/parser",
        "dojo/dom",
        "dojo/dom-style",
        "dijit/registry",
        "dijit/Menu",
        "dojo/domReady!"
      ], function (
        Map, Edit, Graphic,
          parser.parse();
              basemap: "streets",
              zoom: 3
              addGraphics();
                  event.stop(evt);
                  "paths": [
                "wkid": 102100
                  "rings": [
                [-4226661, 8496372]
                      "wkid": 102100
                  "rings": [
                [9862211, 6617856],
                [8922952, 5522055],
                [8922952, 5991684],
                [6105178, 5991684],
                [6105178, 7087485],
                [8922952, 7087485],
                [8922952, 7557114],
                [9862211, 6617856]
                      "wkid": 102100
                  "rings": [
                [2426417, 8535508],
                [6183449, 8535508],
                [2426417, 8535508]
                      "wkid": 102100
              var tool = 0;
              var options = {
    </script>
  </head>
        </div>
      </button>
    </div>
    </div>
    </div>
  </body>
</html>
Thanks & Regards,
Vara Prasad.
