I have an issue with graphics layers on one of our PCs - graphics layers are not visible at all on a 2D MapView. I can confirm that the graphics are indeed in the graphics layer items, with correct geometries and symbology. This happens with the JS API (4.29) as well as in AGOL webmaps, so the issue is not on the code side. When I switch from 2D MapView to 3D SceneView, using the same Map, the graphics layer is visible in the 3D SceneView. The browser used is WebGL2 enabled, as can be confirmed by visiting https://get.webgl.org/webgl2. The PC uses only an internal Intel Graphics card (no GPU) and has only 8Gb RAM. Could the PC resources be the issue here or are there some other tests I can do ?
