I want to get the value of the fill and outline for a FeatureLayer.
Previously for a FeatureLayer of type polygon you would do
featureLayer.renderer.get("symbol.outline.color") // get outline color
featureLayer.renderer.get("symbol.color") // fill colorAs of 4.28, `Accessor.get` is deprecated in favor of using optional chaining().
If you apply the chaining
featureLayer.renderer?.symbol?.outline?.color // will lose its mind if you have linter on
The current workaround is to cast the featureLayer to any before using chaining.
If you have no-explicit-any in your linter the above goes mental and you back at square one.
What is the proper way to get the values, i must be missing something obivious.
I'm surprised this ever worked @Aeseir there isn't a symbol property on the Renderer class. Since many renderers can have multiple symbols associated with them, but I guess this approach might work if the renderer was a SimpleRenderer and the symbol was a SimpleFillSymbol? TypeScript would defiantly complain without doing a lot of casting like this but it's really ugly and I wouldn't suggest it, but I didn't get any typescript or linting errors.
I would suggest querying the feature service for the specific feature's who's symbol outline you want to grab with queryFeatures(), and then get the outline from the graphic property on the feature. https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Feature.html#graphic
As for linting and optional chaining I don't seem to have an issue when using this eslint config I just get an error saying renderer doesn't have a symbol property. Maybe it's something in your linting configuration?
"env": {
"browser": true,
"es2021": true
"extends": [
"eslint:recommended",
"plugin:@typescript-eslint/recommended"
"overrides": [
"parser": "@typescript-eslint/parser",
"parserOptions": {
"ecmaVersion": "latest",
"sourceType": "module"
"plugins": [
"@typescript-eslint"
"rules": {
Thanks @Sage_Wall .
yea i did some minor magic with your sdk to make things work. It makes no sense for it to be referencing the inherited parent class.
QOL recommendation the ESRI team updates the SDK to return the actual Renderer class being used by the layer. User can determine type using the type property that is inherited from Renderer.
i.e.
export class FeatureLayer {
// code omitted for brevity
* The renderer assigned to the layer.
* [Read more...](https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#renderer)
renderer: SimpleRenderer | UniqueValueRenderer | PieChartRenderer | HeatmapRenderer | ClassBreaksRenderer| DotDensityRenderer; // just grabbed a few
Looking at the SDK doesn't look like it would result in breaking changes, it would make it more flexible, and could actually help the ESRI team long term by simplifying some future refactors and feature developments.
