getEffectivePopupTemplate not working?
1472
05-19-2022 04:29 PM
LefterisKoumis
The graphicTemplate retuns null even though there is a graphic on click. Does the getEffectivePopupTemplate works?
view.on("click", function(event) {
        view.hitTest(event).then(function(event) {
         var graphic = event.results[0].graphic;
         console.log(graphic)
         if (graphic){
         const graphicTemplate = graphic.getEffectivePopupTemplate()
         console.log(graphicTemplate)
Tags (1)
LefterisKoumis
Thank you. I found the issue. I was calling an initialization function with view popup.close().
ReneRubalcava
Esri Frequent Contributor
Does the graphic or source layer have a popupTemplate defined? If not, pass true to the method to try and have one created for you.
https://developers.arcgis.com/javascript/latest/api-reference/esri-Graphic.html#getEffectivePopupTem...
Whether support for default popup templates is enabled. When true, a default popup template may be created automatically if neither the graphic nor its layer have a popup template defined.
LefterisKoumis
