Get all the attributes of the selected option in FilteringSelect
1716
05-19-2017 04:19 PM
SaraEL_MALKI
Hi guys,
I have created a filtering Select with five attributes, I wanna get all these attributes after clicking search NOT in "Onchange" method, all what I can get so far is the value of the option selected using .value attributes
uneVoie={nom:feature.attributes['nom'],nom:""+feature.attributes['nom'],ex_nom:""+feature.attributes['ex_nom'],id:""+feature.attributes['objectid'],tenant:""+feature.attributes['tenant'],aboutissant:""+feature.attributes['aboutissan'],id_voirie:""+feature.attributes['objectid'],};
Lesvoies.push(uneVoie);
new FilteringSelect({
store: new Memory({idProperty: "id", data: Lesvoies}),
autoComplete: true,
style: "width: 230px;",
searchAttr: "nom"
}, "voiSelect").startup(); }
All I can do is :
var VoieFound=dijit.byId('voiSelect').value; //ID
RobertScheitlin__GISP
Sara,
Do this:
var fs = dijit.byId('voiSelect');
var item = fs.get('item');
var store = fs.store;
var someValue = store.getValue(item, 'someProperty');
Sara,
Do this:
SaraEL_MALKI
Robert,
your code gave me the error 'store.getValue' is not a function and because of your code I found a shortcut so I will mark your response as correct, thank you sir.
var fs = dijit.byId('nomVoieSel');
var valueOfproperty=item['someProperty'];
