Fully customize PopupTemplate
1107
04-17-2022 01:44 AM
orahlagi
Hello,
I'm displaying a PopupTemplate upon clicking on Point.
looking to fully customize this, according to a custom component that i'm creating (using Angular).
This includes removing all the icons, data etc from the template and instead display a custom data with custom UI.
Is there a proper way to do it ? Thanks.
AndyGup
Hi @orahlagi one suggestion is to use the ArcGIS JS API code from this sample: https://developers.arcgis.com/javascript/latest/sample-code/widgets-feature-sidepanel/. If you need a test repo for experimenting, here is an Angular 13 app where you can add the widget code to try it out: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli.
