I have found lots of info how to use a find or query tasks and then zoom to the new extent of these selected features, but i can not seem to get it to work. can someone please take a look and let me know what i have done wrong.here is my code and a link to fiddlehttp://jsfiddle.net/7vUwE/thanks <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Find Task</title> <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map { margin: 0; padding: 0; width: 100%; height: 100%; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> dojo.require("esri.map"); dojo.require("esri.tasks.find"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); var findTask, findParams, map; function init() { map = new esri.Map("map",{ basemap:"topo", center: [-147.0, 64.8], zoom: 6 }); // draw all sites to the map var sites_layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://ltergis.iab.uaf.edu/arcgis/rest/services/database_test/mapserver"); map.addLayer(sites_layer); //create find task with url to map service findTask = new esri.tasks.FindTask("http://ltergis.iab.uaf.edu/arcgis/rest/services/database_test/mapserver"); //create find parameters findParams = new esri.tasks.FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = ["site_id"]; var sr = new esri.SpatialReference({wkid:102100}); findParams.outSpatialReference = sr } //set the search text to find parameters function execute(searchText) { findParams.searchText = searchText; findTask.execute(findParams, showResults); } //symbology for graphics function showResults(results) { var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25])); //find results return an array of findResult. map.graphics.clear(); var dataForGrid = []; //Build an array of attribute information and add each found graphic to the map dojo.forEach(results, function(result) { var graphic = result.feature; switch (graphic.geometry.type) { case "point": graphic.setSymbol(markerSymbol); break; } //add graphics to map map.graphics.add(graphic); //zoom to selected graphics (not working) }); //zoom to selected graphics (not working) var Extent = esri.graphicsExtent(graphic); map.setExtent(Extent); } dojo.addOnLoad(init); </script> </head> <body> <div dojotype="dijit.layout.BorderContainer" style="width:100%;height:100%;margin:0" design="headline" gutters="true "> <div class="details" dojotype="dijit.layout.BorderContainer" region="top" style="height:30px;"> Find sites: <input type="text" id="searchText" value="fsl" /> <input type="button" value="Find" onclick="execute(dojo.byId('searchText').value);"/> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;"></div> </div> </body> </html>
