Filling a dgrid with the results of an IdentifyTask
1050
05-31-2013 07:42 AM
KenBuja
MVP Esteemed Contributor
I'm building a data viewer application where a user can click on the map and see the attributes of all the features for the visible layers. This is a project I had originally built in Flex that I'm moving over to JavaScript. I would to put a dgrid into an InfoWindow that shows the results of an IdentifyTask for the visible layers in a map service. This would be similar to this sample, but using dgrids instead of tables.
I'm getting close, using this example from Derek Swingley, but I'm hitting a brick wall when it comes to creating the data store for the dgrid. While the dgrid sample shows how to do this using hardcoded field names, I have to do this dynamically. My application will be a template for several different projects, each with their own map service. Additionally, the map services may change over time, with new layers added or different fields being made visible.
KellyHutchins
Esri Notable Contributor
Here's a snippet showing how to do this with a query task. The approach would be similar with an identify except you might have to generate the columns using the layer's field property.
        var layer = results.layers[0].layer;         var q = new Query();         q.where = "1=1";         q.returnGeometry = false;          q.outFields = ["FID", "STATE_NAME","Number_Ent"]          layer.queryFeatures(q,function(queryResults){          //get the field info to build columns          var columns = dojo.map(queryResults.fields, function(field){           return {             field: field.name,             label: field.alias           }          });           //get all the attribute info          var data = array.map(queryResults.features, function(feature){             return  lang.clone(feature.attributes);           });             //create the grid           var grid = new Grid({            columns: columns          },"grid");           grid.renderArray(data);          });
KellyHutchins
KenBuja
Thanks, Kelly, that did the trick. Here's the code I that works. Now to get everything formatted to look good.
    function populateTC1(results, evt) {
        try {
            if (dijit.byId('tabs').hasChildren) {
                dijit.byId('tabs').destroyDescendants();
            if (results.length == 0) {
                console.log('Nothing found.');
                return;
            var combineResults = {};
            for (var i = 0, len = results.length; i < len; i++) {
                var result = results;
                var feature = result.feature;
                var lyrName = result.layerName.replace(' ', '');
                if (combineResults.hasOwnProperty(lyrName)) {
                    combineResults[lyrName].push(result);
                else {
                    combineResults[lyrName] = [result];
            for (result in combineResults) {
                var columns = buildColumns(combineResults[result][0].feature);
                var features = [];
                for (i = 0, len = combineResults[result].length; i < len; i++) {
                    features.push(combineResults[result].feature);
                var data = array.map(features, function (feature) {
                var dataGrid = new (declare([Grid, Selection]))({
                    id: "dgrid_" + combineResults[result][0].layerName,
                    bufferRows: Infinity,
                    columns: columns
                dataGrid.renderArray(data);
                var cp = new ContentPane({
                    //content: combineResults[result][0].layerName + '<br/>Found ' + combineResults[result].length,
                    content: dataGrid,
                    title: combineResults[result][0].layerId
                }).placeAt(dijit.byId('tabs'));
            map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
        catch (e) { console.log(e.message); }
    function buildColumns(feature) {
        var attributes = feature.attributes;
        var columns = [];
        for (attribute in attributes) {
            var objects = {};
            objects.label = attribute;
            objects.field = attribute;
            columns.push(objects);
        return columns;
And this is what it looks like now
[ATTACH=CONFIG]24872[/ATTACH]
