FeatureTable with a map with data from external source
1331
10-18-2023 08:31 AM
JLM
Hi experts,
for a feature table with map as described in code example. Is a webmap required? We like to use the feature table with map, but with our own data. This data is coming from an external source in JSON format.  So I'm wondering if it's possible with data from an external source....
Hope it is, a code example would be very helpful.
thanks in advance
Lee
KenBuja
MVP Esteemed Contributor
You don't need a WebMap, such as shown in this example. You can make a FeatureLayer from a JSON file (shown here), add it to your view, and use it in the FeatureTable.
KenBuja
JLM
Hi KenBuja,
finally it's working.
thank you
Kr
Lee
