FeatureSet in Search widget does not have geometry after setDefinitionExpression applied to the feature layer
2173
12-07-2016 03:08 PM
PitersonPaulgek
We have an issue with geometry.
Case 1 - no issue
We use search widget and features from FeatureSet have geometry
Case 2 - issue
We use search widget, apply setDefinitionExpression and features from FeatureSet have NO geometry.
PitersonPaulgek
As usual, data issue !!
Some feature with shape is NULL.
Robert, thank you for the example code.
RobertScheitlin__GISP
Piterson,
  Can you share some code?
PitersonPaulgek
Robert,
Here you are:
app.searchWidget = new Search({
enableLabel: false,
enableInfoWindow: false,
map: app.map,
autoSelect: false
initialiseSearchWidget();
function initialiseSearchWidget() {
var sources = app.searchWidget.get("sources");
sources.push({
featureLayer: app.featureLayer2,
searchFields: ["Field1", "Field2"],
displayField: "Field1",
exactMatch: false,
placeholder: "Some name here",
maxResults: (app.setting.maxSearchResults+1),
maxSuggestions: 5,
infoTemplate: new InfoTemplate("featureLayer2", "featureLayer2 name: ${Field1}</br>Name: ${NAME}"),
enableSuggestions: true,
minCharacters: 0
app.searchWidget.startup();
// Function to handle the actual search.
app.search = function (activeSourceIndex, searchValue) { //0-address,1-layer1,2-layer2,3-layer3, 'all'-all
app.searchWidget.activeSourceIndex = activeSourceIndex;
var deferredSearch = app.searchWidget.search(searchValue);
return deferredSearch;
app.handleSearchResult = function (response) {
HERE :  to do zoom to the features based on extent/geometry
Case 1 - no issue
Case 2 - issue
We use search widget, apply featureLayer2.setDefinitionExpression some place BEFORE app.searchWidget.search(searchValue) and features from FeatureSet have NO geometry.
Piterson,
   Hmm. When I apply a definition expression to a source layer before the search I don't seem to have any issue, as seen in this sample: (search for "a" and you will only get democrat senators that have a in their names and clicking on the suggestion takes you to the geometry)
<!DOCTYPE html>
<html dir="ltr">
<head>
   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
   <title>ArcGIS API for JavaScript | Search widget with multiple sources</title>
   <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
   <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   </script>
<script src="https://js.arcgis.com/3.18/"></script>
   <script>
      require([
        "esri/map", "esri/dijit/Search", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!"
      ], function (Map, Search, FeatureLayer, InfoTemplate) {
         var map = new Map("map", {
            basemap: "gray",
            center: [-97, 38], // lon, lat
            zoom: 5
         var search = new Search({
            enableButtonMode: true, //this enables the search widget to display as a single button
            enableLabel: false,
            enableInfoWindow: true,
            showInfoWindowOnSelect: false,
            map: map
         }, "search");
         var sources = [];//search.get("sources");
         //Push the sources used to search, by default the ArcGIS Online World geocoder is included. In addition there is a feature layer of US congressional districts. The districts search is set up to find the "DISTRICTID". Also, a feature layer of senator information is set up to find based on the senator name.
         sources.push({
            featureLayer: new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/CongressionalDistricts/FeatureServ..."),
            searchFields: ["NAME"],
            displayField: "NAME",
            exactMatch: false,
            outFields: ["DISTRICTID", "NAME", "PARTY"],
            name: "Congressional Districts",
            placeholder: "Congress Member Name",
            maxResults: 6,
            maxSuggestions: 6,
            //Create an InfoTemplate and include three fields
            infoTemplate: new InfoTemplate("Congressional District", "District ID: ${DISTRICTID}</br>Name: ${NAME}</br>Party Affiliation: ${PARTY}"),
            minCharacters: 0
         sources.push({
            featureLayer: new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/US_Senators/FeatureServer/0"),
            searchFields: ["Name"],
            displayField: "Name",
            exactMatch: false,
            outFields: ["*"],
            placeholder: "Senator name",
            maxResults: 6,
            maxSuggestions: 6,
            infoTemplate: new InfoTemplate("Senator information", "Name: ${Name}</br>State: ${State}</br>Party Affiliation: ${Party}</br>Phone No: ${Phone_Number}<br><a href=${Web_Page} target=_blank ;'>Website</a>"),
            minCharacters: 0
         //Set the sources above to the search widget
         search.set("sources", sources);
         search.startup();
         search.on('focus', function(){
           search.get("sources")[1].featureLayer.setDefinitionExpression("Party = 'D'");
   </script>
</head>
<body>
   <div id="search"></div>
   <div id="map"></div>
</body>
</html>
PitersonPaulgek
