Feature Form - Creating a Choice List without Having to Use Domain Values?
1485
07-19-2021 02:12 PM
IanPeebles
Hello everyone.  I am currently exploring the JavaScript 4x environment and interested in starting the conversion of apps from 3x.    In the feature form, is it possible or has anyone been able to create a choice list without having to rely on domain values? If so, how would this be done?
For example a Status field:
The current choice list exists only because of an assigned domain to the field.  I am wanting to avoid this if I can.
Can this be done?
Thank you!
HamishMorton
Hi Ian,
Are you looking to dynamically pull from existing values in a field or creating an immutable list from which you can populate values?
The folloiwing documentation may be of use:
Hamish
ipeebles
I just wanted to do a follow up.  When using a form editor, can we predefine values to use instead of having to assign domains to the field?
